Zero Rates on the Front Axle
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Are you saying the ORD disconnects/end links will pivot or rotate enough to use the sway bar with axle pushed forward 1” without offsetting the frame mounts forward for the sway bar?
With the lift and moving the axle forward with the Zero Rate you may be at a neutral position with the sway bar. Even if its not, the sway bar end link would be pushed to the rear a little. Since the suspension mainly moves to the rear for compression, it may not be an issue as it would be pulling the end link to a more vertical position.
Washington
Makes sense. Because as of now, if I move the axle forward at all, I’ll have to fab up some offset sway bar drop brackets on the frame mounts to even use the sway bar.
Derick C.
Auburn WA
Derick
454/700r4
If you want to try the sway bar disconnect I have a set I'm not using.
Washington
Hey thanks neighbor!
Once I’m able to spend time on it I may take you up on that. Appreciate it!
JoshinIT
