- Apr 11, 2017
- kansas
- Rick
- c20
You don't have to tow it does the steering wheel and shifter unlock? If so take the electric part of the ignition off the column I think it's 2 5/16ths screws,don't lose them. Anyway slide the ignition switch until the dash lights come on,push your push button,drive it home then slide the switch back. Then we'll start going through how to fix it. If taking the switch down is too much trouble make a jumper + post on alternator,to plus post on distributor hit the button it will run until you pull the jumper off. That boys and girls is how they used to hot wire cars before column locks,not all this sparks under the dash crap like in the movies. A hot wire and a screwdriver to short the starter on a manual roll it and dump the clutch.
