75gmck25
- Oct 13, 2016
- Northern Virginia
- Bruce
- K25 Camper Special TH350 NP203
I installed a new set of heads, and now I have an exhaust leak on the passenger side where the heat riser is installed on the stock manifold. Clearance is tight around the flange, but I think I got it tight.
When I pulled off the manifold there was no gasket between the heat riser and the flange above, only the round gasket where the header pipe connects. However, I've looked online and there are three-bolt gaskets that look they would fit between the heat riser and the flange. This is the type of gasket I mean https://www.rockauto.com/en/moreinfo.php?pk=2589708&cc=1159073&jsn=525.
The header pipe seals into the heat riser using the standard round gasket, so it seems like there may be somthing needed on top of the heat riser. Maybe I was just lucky enough before to get it to seal without a gasket.
Should there be a gasket between the heat riser and the flange above it?
Bruce
Bruce
