SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
I have recently installed my newly rebuilt NV4500 and Twin Stick NP205. As usual, the domino effect has reared it's ugly head and made things difficult. The problem is, there's not enough real estate on the trans tunnel to accommodate three sticks poking thru the floor. Now I gots to figure a solution to make it look like its not a trainwreck of bad ideas. I tried everything to get two shifter boots to fit and not overlap but gave up in frustration. I also have to consider the way they mount and the order they go together as I now have a removable floor cover. Eventually the carpet will go over the cover and the bezel over the carpet. I have virtually zero access from under the truck due to the size of the trans and associated shifter linkage on the t-case.
I concluded I would have to start from scratch. I opted to fab a bezel up with 1/2 x1/2 square tubing. One piece that incorporates both shifter boots. I can salvage the boot from a previous project for the Trans shifter I think. I'll get someone to sew me up a smaller boot with two holes for the T-case boot. I think I'll use some long machine screws on the corners of the bezel and install some Rivnuts in the removable cover. That way I can just screw the bezel to the floor from above and it will look good. This is what i got so far. Questions/comments/suggestions all welcome.
