well i finally found some 8 lug rims
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
they are 15 inch which is ok from summit racing they are made by us wheel series 70 i called about it and they told me 194$ with change shipped to my door free shipping!
so when i get my some clams saved up i can buy my uncles old truck and have good cheap rims and tires because you cant find tires that are on this truck .
7.00-17 really skinny bias nylon tire split rim with a square bead :yucky:
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Be sure 15" wheels will fit over the rear drums if it has a 14 bolt. I'm not 100% sure they will, which is why I converted mine to rear disk brakes.
X2...and if they don't I hope it's not too much of a pain to return them...
crazy4offroad
Curt
K-10
350/SM465/NP205
I still cant understand why 16.5" tires are hard to find in your area. What kind of tread are you wanting? Summit sells truck tires too, but National Tire & Wheel might be cheaper.
crazy4offroad
Curt
K-10
350/SM465/NP205
Wow I'm seeing it now, aint that some ****. Looks like Super Swamper is the only one still making 16.5s, and they are the big mud tires. The other vendors I did see selling 16.5" tires, only have 33x12.50s. Wierd, where have I been lol.
I never knew they made a 15" rim with 8 lugs.
X3, make sure you got clearance on your rear drums AND front calipers for those things to fit!!!!
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I'm confused. So it now has 17" rims that are narrow and hard to find tires for? And c4o is talking about 16.5" wheels?
A quick search turned up some 16" rims in Louisville which looks fairly close to you. Nothing fancy but if you're just looking for something common to roll on these could be had for less than $200.00 easy.
http://louisville.craigslist.org/pts/2134222257.html
Plan on doing some grinding on the front calipers, and maybe running a spacer in the rear.
What backspacing did you order?
jake wells
Can i be me?
jake
custom deluxe 10
i didn't order anything yet but today i located a local shop that does tires for medium duty and heavy duty truck rims and tires.
they told me we don't have any 700-17 tires in stock but we can get 750-17 which are about an inch taller and they are a mud and snow tire 6 ply rating.
of course me being worried i asked if they do split rims and they said no problem as they have a safety cage.
they said the price for one tire mounted,balanced and the old one disposed off was 90.00 so 360 plus tax and i thought that was a great deal.
f1shman
http://lexington.craigslist.org/pts/2130461388.html
Look at the text listed between the phone numbers. The guy has five 16" rims for $125. Those 16" rims should clear any brakes you have on your truck and allow you to find tires a heck of a lot easier. Being able to buy five rims at once is nice too since you wont have to search for a spare later on. The guy is about 2 hours away from you, but I'm sure if you do a bit of searching through your local classifieds and/or call some salvage yards in your area you'll find similar deals.
Now, onto my spiel about split ring rims.
If you are not planning to restore that truck back to 100% stock condition, you should not be using those split ring wheels. That style of wheel is inherently dangerous both to people who are mounting/dismounting tires on them and also to people who merely work around them! If that ring is not properly seated onto the rim at the time the tire is mounted, or if the ring has any defects in it, you might be working on removing a wheel one day to check your brakes and have the spring loaded ring come off and strike you dead. Don't think that it can happen? Check some sites for reference:
http://www.nclabor.com/osha/etta/hazard_alerts/MultiRims.pdf
http://www.ehow.com/list_7426633_dangers-split-rim-wheel_.html
http://www.workcover.nsw.gov.au/for...ngers_with_split_rim_tyre_assemblies_5899.pdf
Spend some time and find a good deal on some used rims and get rid of those split rings.
Wow....that's some pretty scary stuff there...
crazy4offroad
Curt
K-10
350/SM465/NP205
Yeah those are definately dangerous, much different than the hummer wheels I was talking about earlier.
JChoppin
