Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
Carefully inspect the battery cables. They can be corroded inside the insulation where it’s hard to see.
If the battery load tests hood, before spending another dime do a simple voltage drop test.
Get a voltmeter, put the positive probe of the meter on the positive post of the battery. Put the NEGATIVE probe of the meter on the POSITIVE cable end AT THE STARTER. Crank the engine while looking at the meter. Whatever the meter reads is the voltage lost in the cable. If it’s more than a couple tenths of a volt, either the cable is undersized, or you have a bad connection somewhere.
You can do the same thing on the negative cable, just reverse the connections.
Another possibility: inspect the advance weights in the distributor. If they are corroded, they can stick in the advanced position. Remove the cap, twist the rotor, the rotor should snap back to it’s original position. If not, inspect, clean and lube the advance weights. If they are sticky, reset the timing once they are fixed.
