13matsc
- Apr 9, 2024
- Norway
- Mats
- C2500
Hi guys,
Original dual tank setup. Right side tank fuel gauge peaks at 3 o clock when selecting that tank. Removed the chassis ground and worked everything with the wire brush, then reattached. Still same problem. This verifies that the fuel sending unit inside the tank is faulty? Check my picture to see if the ground cable i worked on.
Left hand side works as it should. Switch, the switching valve and the resitor on the gauge itself should be OK?
Would like to be as certain as i could before dropping that tank, does not look like a fun job.
