Vent tube
YO MUDA
Norman okieHOMER
Jimi
Does the rear end vent tube suppost to be open or closed? Theres a bolt in the end of my hose, and it doesnt look like it belongs.
Swims350
Logan WV
none
they have a bolt looking cap on them that lets it vent but keeps crap out of it for the most part.
towman
harrisburg pa
jay
v10
factory is a hard plastic, though i never tried it have been told a nipple off of a baby bottle will work
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
If it's an actual bolt, it does not belong there. Advance Auto sells the check-valve type vent caps. If it's a 4WD and you cross deep water/mud you may want to plumb all your vents- front axle, rear axle, and transmission, to the highest point you can. I have all mine tee'd together and plumbed to the cowl with one check valve vent cap.
x2. Take he bolt out, and replace it with the check valve. I see you are local to Moore, had you been 2 days earlier, I coulda given you a hose, valve and clamp that bolts it to the bottom of the bed. I junked the truck.
How did you hear out this place Muda???
YO MUDA
Norman okieHOMER
Jimi
Thanks for the good info. HotRod, I saw your add on craigslist for a parts truck and the link you put in the ad. Good thinkin.
Ahhh Cool !!! Yeah, I scrapped that truck this week. And let the rear end go with it too. Didn't want to, but was out of time after being sick the last 2 weeks and not getting it stripped like I wanted too. But I sure could grabbed the Rear end hose. I had already it unbolted too since I was in process of taking the rear end.
holdennaz09
