Vendor discount codes or deals
Camar068
10 yrs Air Force
This used to be talked about and has been used by several members here. We used to see it for $9.99 frequently. Since COIVD and 2020, I've not seen it at this price since then. So here it is, Finally got there again. IF you have any cheap paint projects in your near future, I'd pick up a couple or 3 of 4. I still haven't used the 2 I have soo no need for me. The 20oz HVLP Paint Gun that does a pretty good job when you thin your paint properly. https://www.harborfreight.com/20-oz...ray-gun-62300.html?_br_psugg_q=hvlp+spray+gun
Also, I've went on about this light a few times. At $17.99 get a few. aa$19.99 used to be cheapest you'd ever see it and I'd buy them then. I have 4 of them in various places and yet to have one disappoint me. Of the 4, I do have 1 that I've had for about 7 years and use it the most and it's been bounced and tossed around in the roll back use almost daily, but it has finally a developed a failure. The charging port don't work unless you hold the cable into it. So I take the battery out and charge it on my vape battery charger since it's just the common 18650 format battery. It doesn't require charging that often so no big deal. I still use it in the truck, that way if it gets stepped on, left on a scene or broke, then no huge loss. You should get a few of those too.
https://www.harborfreight.com/390-l...work-light-56329.html?_br_psugg_q=braun+light
DanMcG
Central NY
k10 k10
I used the purple gun for most of the epoxy on my truck, It works well for that. I've since moved up to their green gun for $24 . No sense in using your $500 finish gun with something you're going to block down anyways.
sublimeobs
NELA
Knucklehead
Picked this up at the Ft Worth Goodguys Show this weekend.
Vendor: LMC Truck
Code: LSNTXLMC
Good Until: 05/12/2024
Deal: 10% off your order
dob555
