Vapor lock issues?
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I have been trying to chase down a problem with my 305 hesitating off the line and occasionally losing power for a second and then it coming back. I thought it was the carb so I switched to a Carter AFB, stabbed in a brand new distributor and rebuilt my carb.
This problem is only happening when its been running at operating temp for a while, when the ambient air is warmer it runs worse. fuel pump is a new one from Orileys. Anyone have any thoughts?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Coil? :shrug:
I don't miss trying to figure that **** out. Is that an HEI or separate coil? I agree with skt to try that.
animal
Lee
c10 silverado
350ish
Actually had a simular problem after I put my headders on. The fuel line ended up actually sitting against the header on the passenger side headder and was basically boiling the gas in the line.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Adjust the accelerator pump for a longer throw on the carb, see if that helps. It may be running a little lean, too. Might need to re-jet to the rich side.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Cant be a coil, I just put a brand new distributor with a new cap and coil. I adjusted the accelerator pump and no difference. The next thing I was going to try is exactly what C4 mentioned, change metering rods and fatten it up a little.
Im wondering... It cant be leaned out if its running fine at operating temp with the choke open. Its only after driving around for a while it starts.
Has anyone ever herd of new fuel pumps vapor locking? I had a brand new fuel pump on my colt that would vapor lock like crazy.
If I wrap aluminum foil around the fuel line and it still does it maybe I should try another fuel pump?! I dont know. Its driving me crazy.
crazy4offroad
K-10
350/SM465/NP205
If it doesn't do it at idle, your idle air screws are right, but driving around the metering rods/springs/jets come into play. The plugs might tell the tale the best. If they look "really clean" it is probably running lean. I didnt think changing the accellerator pump travel would cure it, but it takes it out of the equation. Steady throttle tells me it could be the metering rods/etc. Otherwise there could be a vacuum leak but without backfiring issues I doubt that's it too. It would be easier to run a vacuum test than to start fiddling with the carb though.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Maybe it is a vacuum leak..... that would make sense. I've been talking about getting a gauge for way to long now.
mrt
Reno
Troy
C Series
Have you tried a heat sheild and a phenolic 1 inch spacer? That might help.
Pugs Speed Shop
