ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
I pulled my plugs to check the color, and I noticed the dreaded oil on the threads. The outside of the heads below the valve cover gaskets are dry.
It does not visibly smoke from the tailpipe. One plug looked a little black, but not coked up with oil. The rest were normal.
Engine has less than 2000 miles on it, purchased already rebuilt and in the truck. Or, at least it looked clean internally, and could see crosshatches in the cylinder bores and .030 stamped in the pistons with my scope.
I plan to do a compression check but unless whatever shop made a mistake, it’s unlikely that it would be rings.
I have no problem redoing the valve seals but apparently camel hump heads used an o-ring and it sounds like they can be less than reliable or problematic.
I don’t want to get the cart before the horse, but if I do end up replacing seals, what would be the best style or brand? Apparently some of the new style seals require machining, and I’m not taking off the heads. Any input is always welcome.
Thanks,
Chad
Thanks,
Chad
