DoubleDingo
- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Replaced the vacuum hoses on the truck. Some were new but I replaced them anyways.
My question:
On the sticker, does the "nut/bolt" looking part of the EFE TVS and SPARK TVS on the diagram indicate the portion you put a wrench on to tighten them? If so, does it matter how the hoses are routed from the respective TVS's?
I ask because I noticed the hoses I removed were routed 180 out on those. So I routed them according to the "nut/bolt" portion on the sticker. I guess once everything is hot vacuum will flow through the hoses, but I am sure the engineers intended the vacuum signals to flow one way, not any way.
Am I correct on this? Or did I mess up the routing? Basically I routed everything according to the sticker, assuming the nut/bolt symbol of the TVS's indicates where they screw into the intake and thermostat housing.
My question:
