- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Using a 1/2 socket and racthet, remove the 5 bolts that hold the piston retaining ring over the piston, and the 2 pump halves together.
On the last bolt, you should use one hand to support the front half as you take the bolt out so the front half does not drop. Or have the pump assembly face down in the hole of your table or workbench to support it..
Here are pics of both halves now seperated.
Now, simply lift the back half out of the front half. Notice the Th350 used pump gears rather than a Vane pump like the 700r4 and 4L60-E use. This is certainly considered much stronger than the Vane style pump.
