ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
I know there’s been many posts on temperature gauges, but just wanted to ask that if my temperature gauge reads on hot all the time, and I know if there is power getting to the sensor, then it is likely the gauge? I know it is getting power to the sensor through the wire because I accidentally dropped the wire on the intake manifold when I was trying to reposition it and it sparked and not just a little bit. I’ve just started down this road and I have errands to do today, but thought I would check in here before I start buying parts for it. Thanks in advance! I’m not wholly inexperienced when it comes to wiring, but sometimes I am a little bit rusty and don’t understand the rationale, so please feel free to be elaborate it’s only one wire, so I’m guessing it’s grounded through the intake manifold.
The set up I have has the temperature sensor inside the gooseneck where the thermostat is. I just replaced some gaskets, and put some sealer on the threads of the temp sensor when I put everything back together so perhaps that is keeping it from grounding? SBC 350 for reference. I find it concerning that if it is a ground problem (too much sealant?), then it seems like the gauge would go back to cold when the key is off?
