MrMarty51
- Oct 25, 2012
- Eastern Montana
- Martin
- K20
NP 203 transfer case spider gear thrust washers.
It appears that there was/should be, a coating of babbit on these thrust washer, mostly all I see now, on the wear surfaces, is copper.
I do`nt know how critical the babbit coating is, but, I am sure it would affect the endplay of the gears, and, I do`nt know how much end play is too much but these do seem to have quite a bit.
I will be installing the Mile Marker 4X2 conversion kit and it sets directly on the spider gears so I do`nt know if they will be turning much at all after that anyway.
Anyhow, not being real familiar with transfer cases I thought I would throw this out there for a bit of Professional help.
Thank You
Martin
Thank You
Martin
