Stimulus Check, Header Nightmare and Regrets
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
You say direct, was there another? I must've not qualified if there was lmao
Unemployment supplement was the other. The ethanol plant I work for shut down in early April thanks to OPEC, I just went back last week. Was furloughed and had to take unemployment during that time. Loss of demand for gas kept it shut down as long as it was. Plant isn't even running yet, but we are prepping to restart in August.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Oh right.
I followed along with the "free money" story on the 2nd check maybe.... 2 or so months ago? Then never checked back again. Figured at some point maybe I'd see a jump in the bank account, and if not, whatever.
I'm not loaded with money or anything, it's not like I "wouldn't have noticed" I just hadn't stayed current with the latest updates on their second "relief"
Thankfully I'm blessed to be buried in work this entire time with dad at our shop.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
No check for my wife or myself. We’ve been stimulating the economy though. No regrets so far. Been getting toys for the property and business.
ali_c20
Austria
Alexander
C20, K5
First, I would like to say my truck ran fine with stock exhaust manifolds and I was happy with them…….Then I got my stimulus check. For some reason the money started burning a hole in my pocket and I needed to buy something for my 1975 Chevy Stepside. I decided to get some headers. Due to being lowered, I went with the mid length so I wouldn’t bottom out and scrape over speed bumps, etc. I got the Hedman Street Headers. They came with a temporary coating that I had to media blast to remove. I thought I was saving a couple hundred by not getting the ceramic coated. All the time and work to remove the coating and clean and paint with VHT flameproof ceramic paint, I wish I would have spent the extra money and bought the ceramic coated ones .
Upon test fitting them, I found they were made for the turbo 350 trans. I had to trim about ½” off my 700R4 case for clearance (ball and socket type headers). After installation, I found I had to change to “shorty” plugs due to the clearance. I also used the plug wire sheaths to protect the plug wires from getting burnt. I didn’t care for the look of the sheaths and chose to get the under header Moroso wires. They are 8.5mm covered the entire length with heat sheathing making them 9.8mm thick. I could only find one wire loom capable of fitting this thick of plug wire. Next came the starter. The solenoid was too close to the header (heat wise) so I had to put the Powermaster 9100 (I heard about on this forum) so I could “clock” the starter to move it farther away from the header. It has been like dominos, one thing after another. I’m now wishing I would have just kept my stock manifolds, with stock spark plugs and wires and spent my stimulus check on something else for my 75 Stepside. What a nightmare!
What has everyone else spent their stimulus checks on and does anyone else have any regrets?
Long tube headers....had to chop and modify my exhaust system etc.... excessive heat, rust ( I also saved a few bucks with not buying ceramic coated ones :banghead:) and I had to re-torque the bolts every 300 miles because the headers started to leak.
Now I'm back to ported stock manifolds and happy with them. Don't know why I thought that I need headers.
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
If you are going to run headers here is one small mod i recommend to prevent header leaks on exhaust ports. Cut the supporting flange between the ports so the header has less chance to leak.
ali_c20
Austria
Alexander
C20, K5
I did that. Still leaked' but less. I think the headers hated me.
Big Chip
Michigan
Kevin
C35
These seem to work so far, no problem with fit and I’m using the same plugs and wires. I guess time will tell but if these don’t work I’ll go to cast manifolds. I’ve got about 300 miles on these now with the old exhaust temporarily cobbled in so I had mufflers.
PS-I don’t recommend you put the muffler within an inch of your electric fuel pump. You will have problems. Thankfully I’ll have a new exhaust system tomorrow!
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
The 84 has headers on it, had a Blazer with them. When the funky bolt thingies would come loose I throw them away and use a 11/2 by 3/8 bolt with a nut on it, screw the bolt into the head,as far as it would go then back the nut down and tighten the shiznic out of it against the header. Never had one of these back off?
Far as the government check, First Treasury check I ever cashed and spent it all on domestic beer and cigarettes. No regrets.
Catbox
Peter
C20 Silverado Camper Special
I haven't spent my stimulus yet.
It just sits in the bank.
But soon I will be redoing the whole exhaust on the pickup truck.
That will include new headers for the big block.
K5ride
Apple Valley, CA
Steve
C10 Stepside
Those headers look nice. The plugs and wires look like you have easy access. What brand are those and are they full or mid length? thanks,
Catbox
Peter
His will be different than yours as his is a big block.
80BrownK10
Greenwood, SC
Nate
The headers I put on my 76 coming up on 2 years ago (that were already used and old when I got them) still are working good and haven't given me any troubles, got them for a good price too. A case of Natural Light. The Rustoleum white BBQ paint has been holding up good too.
Didn't get a stimulus check either.
Your old enough right? Can your parents claim you as a dependent? Did you go into the website and fill out your info? Or do you make more than what's the cutoff for nothing at all like 90k or something?
80BrownK10
Greenwood, SC
Nate
Oh right.
The second one is in the works. It sounds as if there will be a second round of checks. As of right now it's written to be the same amount as the first one. At least the senates version they just sent back to the house.
Vbb199
Salisbury NC
Vince
First relief check is for any dependent of any age you claim
I believe the guys 18 or 19.
His parents may claim him.....
BUT...
I just assumed he made the big bucks lol
legopnuematic
Licensed Junk Dealer
MO
Spencer
Still claimed as a dependent, parents got the extra bread in theirs because of me. While it would have been nice to get that extra $$, I'm not too concerned about it, I keep the mindset of no such thing as a free lunch, there is ALWAYS a catch to these "Free" things in life, even if not immediate.
Haven't reached the point in life yet where I'm above the cutoff... although at 19 I still have some time ahead of me yet.
Villano
