Steering box frame reinforcement weld in plates
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Man I dont see how those Plates/brackets even line up. I had the worst
of luck trying to install mine and just left it out since there were BIG gaps
between frame and plate. I just ended up superduty welding the frame.
Fast Forward to 5:30 mark.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
I'll be sure to check mine out when reseal time rolls around. It was an actual camper special in its previous life, so its worth checking out, even being only 2wd. Very much sooner than later. Steering is sub-system two on the punch list.
It's definitely more common in 4x4s and 20/30s that were worked hard but can happen on C10s. My buddy's '86 shortbed was cracked bad enough the box nearly pulled off the frame and was driving horribly.
dragstews
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
Lock & Load time will be here when the brace shows up ..
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I think mine got cracked from having P295/50 tires with 15x10 rims. Pretty wide for a front tire.
Sorry Dragstews, Not trying to highjack your thread!! :cheers:
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Any pics of the bottom support plate welded in?
dragstews
Jesse
R-100
406 ci SBC
I'll take some ..
Got to warn you, I'm not fond of laying on my back and doing overhead welds .. Even suited up still get burns on my body .. :shocked:
(When that happens there's a few words that inadvertently are said that would make a Preacher blush)
There's about 8 welds on the top side of the bottom plate that I didn't get photos of ..
I may clean up the welds when the truck is on a horst ..
idahovette
Weiser Idaho
Perry
K20-K10
Most Preachers I know won't blush, but they shake their heads knowingly......lol
brooksman9
Olive Branch, MS
Patrick
350 & 305
Thanks. I probably need one of these for each truck. Wonder if there is any difference in the ORD one and others? Rough country’s is cheaper with free shipping.
dragstews
Jesse
R-100
406 ci SBC
Heavy Freaken Duty ..
Very well made ...
brooksman9
Olive Branch, MS
Patrick
350 & 305
Just wanted to show what I will have to fix on the white truck. Not trying to hijack.
3dbello
