- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
yea air works if you can do it, like you said, place to do it and tools or if it'll hold air. I had one that wouldn't hold the air, had to jerk the heads off.
So true. If you have severly worn engine with tired rings or burnt valves, the cylinder won't hold the air. It'll just escape into the crankcase or the come out the vavle port, so in that case, you have no choice but to do the rope. Honestly though, if its that bad, valve seals aren't even a quick fix and its just no worth doing. Yank the motor and start a new build or find a decent used motor.
