SM465 to NV4500 1975 C30 2WD
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
Well i heard of this swap but what mods do i need to do because i don't think it would be just a trans swap and be done.
I have a 14 bolt FF rear it is 2wd. 1975 c30 w/dual rear tires
2 piece drive shaft it has carrier bearing and splined coupling that moves in and out with alamite fitting.
my truck has a mechanical clutch set up not sure how it would respond to the nv4500.
i don't know how many splines there is on a sm465 input shaft and i don't know what splines the nv4500 has
i don't know if i would have to swap a clutch for a different one for it to work.
don't know if the nv4500 would bolt to the old bellhousing.
There was a guy here selling a 3/4 ton blown diesel motor 94 model with an NV4500 for $600. The $600 alone would have made the NV4500 swap cheap, then sell the other parts like the 14b FF rear axle, body parts etc, and you'd damn near have a FREE NV4500 swap. IF I had the $600 in cash I"da bought just to part and sell. Normally the NV4500 is gonna cost $600-$1000 just for the trans. Then the bell housing and other stuff you need for the swap. It is true, the NV4500 WILL NOT bolt to the SM465 bell housing. Being your truck is 2wd, it's not a hard swap though. The 4x4 swap gets expensive with adapters and driveshaft mods.
How come we haven't seen pics of this dually C30? Is it a Cab and Chassis C30 or a Pick up truck C30 with hips on the bed???
jake wells
Can i be me?
jake
custom deluxe 10
here is the photo's when i got it in march of this year.
OH yeah, I member now. That looks like it was pick up, not a C&C.
jake wells
Can i be me?
jake
custom deluxe 10
it had a wood stake bed when it was new but the owner told me in 1991 it was replaced because it had rotten to nothing the bed that is on it is from a 1970 ford f350.
So maybe it is a C&C then. The VIN # would tell you for sure.
It's a 14bolt rear, so that automatically means it's a cab&chassis model.
Ahhh yes, or it would have had a Dana 70 for a dual 1 ton.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
My vin number is CCY335B164766
<LI>C Chevy
<LI>C 2wd
<LI>Y 454
<LI>3 1 Ton
<LI>3 Cab & Chassis
<LI>5 Model Year 75
<LI>B Assembly Plant Baltimore, MD
The rest are sequence #'s which means you had the 64,766th one made that year. Usually start at 100000 so it it were 264766, then you'd had the 164766th one made.
jake wells
Can i be me?
jake
custom deluxe 10
<LI>C Chevy
<LI>C 2wd
<LI>Y 454
<LI>3 1 Ton
<LI>3 Cab & Chassis
<LI>5 Model Year 75
my RPO code thingy show LS9 V-8 ENGINE- 350 CID also has a 350 emblem in the grill never had a 454 in it and this truck is bone stock original drive train wise
Then the Vin letter for 3rd digit should be an L, for CCL... L designates 350 4bbl. I guess it's possible could have been 2 Y's. The Y I am seeing says 454 4bbl (P Series) an your truck is a C series, so it's possible my chart is not showing all the letters and there might be 2 different 350 models.
ccacuna12485
