SM 465 to some 5 or 6 speed
tx_truckin
Fort Worth
Jason
I have a SM 465 in my 1983 Chevy k20 with a 350 and at 60 I'm pushing 3000 RPM's.
Is there a 5 or 6 speed transmission that I can change to that will give me one or two more gears so the rpms will go down and gas mileage will improve.
Specs on truck:
1983 k20
350 4 bolt main
sm465
np205
4.10 rear end
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
nothing that is a direct bolt in... and being a K20, did you put the 205 in it? it didn't come that way from the factory. if its a 208, you may have some luck getting an NV4500 in there, no way i'd go with anything smaller than that.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
I dont know what Tire size you are running, but if you go to a taller tire it will ower your RPM'S. Try playing around with different tire sizes on some of the online calculators
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
by my calculations, he needs to put the tires on the truck back on the wife's prius, and put some real tires on the truck... 28" tires on a 4x4? either that, or he doesn't have a tach and is guessing the RPM.
Swims350
Logan WV
none
well somebody correct me if I'm wrong but aint 5 and 6 speeds only better then 1:1 when in like 5th only or 6th? meaning anything less then your last gear is equal to having a 4 speed?
I would agree I got 28's on my stock 88 and they are too small I hate it. run some 33's or 35's on it. Cheaper in some ways and easier then a trans swap.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Overdrive (5th gear) on an NV4500 is 0.75:1
78shortandwide
Denver
Tom
Specs on truck:
1983 k20
350 4 bolt main
sm465
np205
4.10 rear end
I'll trade you axles. I have a Dana 44 and a 12 bolt with 3.73 that might help!
Cryptik
