Rough Country 4” with 35’s
JACK34
Banned
OTR TRUCKER
JACK
They ride very rough, that's all. For the same price you can get a set of Tuff Country EZ-rides that ride 100% better.
I'm calling BS on that my man. I spoke with Rough Country, Tuff Country, and Offroad design.
I haven't kept up with modern post-covid pricing, but it used to be that the front springs themselves were not priced that far off between Rough Country and Tuff County. Or others really. But Rough Country always had the cheapest kit price, complete with shocks.
Soundmound
North Central Washington
Dave
Scottsdale
I purchased a Rough Country leveling kit for my '02 Silverado because it was the least expensive all in kit. Don't think I'd do it again to be honest. It's just ok ride quality wise, better shocks might help, but I'm trying to get out of the truck anyway.
BS on what? I'm not sure what you are saying here? I'm glad you spoke to them... what did they say?
I've ridden in a square with rough country springs and it was crazy stiff. I have Tuff Country EZ ride 4" springs on the front of mine and they are about the same as stock.. maybe a bit softer. ORD springs are made by Deaver and are in a totally different class than the previous two springs. They are top notch... but you are going to pay for it. I got the Tuff country springs used, but uninstalled for $100 locally
T-roy K10
mississippi
Troy
I can tell you skyjacker soft ride 4” springs ride like a lawn tractor.
Fastduramax
Uranus
K10 Silverado
Your lawn tractor must ride like it's on a king size memory foam mattress because my K10 with Skyjacker 4" springs on all 4 corners and their best shocks does... Far better than anything else I've spent money on and I've tried them all over the years with the exception of a few newer or more recent Softride copies... That said there is a better ride at a nominal expense, a buddy and I opted for the BDS Glide Ride Fox Shox combo in his same year K10 and all I can say is OMG ! BDS has a very different approach to building their spring packs and apparently they nailed it...
T-roy K10
mississippi
Troy
I had an 83 dodge back in the day with an 8” lift (don’t remember the brand) that rode like a Cadillac compared to this K10. I could weld steel tubing from the frame to the axle and it would ride the same. i bought it with a 4” lift and to soften the ride I bought the skyjacker soft ride lift. made no difference. So I swapped the skyjacker shocks out to rancho 9000s on The softest setting…no difference. I added sway bar shackle links to make sure the sway bar/axle were not binding from bad travel angle... no difference.
loosened the spring and shackle bolts to make sure they weren’t binding…no difference.
im 230 and can bounce on the front bumper and the only thing that moves are the tires.
Fastduramax
Uranus
K10 Silverado
Dammit Troy that sucks ! I'm a stout buck 70 so I can't bounce any spring lol, anyway I wonder if they lost QC over the years or if they still make a HD spring kit as they actually use to back in the day and that's what you received ?
T-roy K10
mississippi
Troy
don’t know. They looked just like the ones I took off. The only difference was the skyjackers had plastic pads on the tips.
Wrenchersllc
