Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
I'm replacing my old Autometer gauges with new Sport Comp style ones to match all the other Sport Comp gauges I already have in the instrument panel. Back in 1995 when I restored/customized my '74 C10 I had bought one of those three gauge clusters you could get to just give me something to keep up with the gas, oil, and volts/amps while I was driving around with just a striped down cab on the frame. It had no dash or any other things in the cab. So when I was finishing building the instrument panel out side the truck I just left three of some that I had bought other than the Sport Comp ones I was going to permanently install.
Autometer had four types of gauges back then, the cheap gauges called "Auto Gage", they still produce those. Then a mid grade gauge which were plain jane gauges with nothing at the bottom identifying them except for "Auto Meter". They don't make this gauge anymore. Then a step up to pro gauges of many styles. I got the "Sport Comp" ones because I like the race look of them and most other racers use them. Then the big time gauges "Pro Comp". Those are the liquid filled gauges. Professional racers use that type, and a mix of Sport Comp gauges. The Pro Comp gauges are a lot more expensive than any of the others.
So that's where I'm at today and that is I'm putting in my Sport Comp volt meter, as follows.
Below center of the pic, white gauge housing with the two long brass screws, this is the new type gauge housing Autometer makes, it's plastic and is longer than the older shinny metal housing gauge to the left of the white housing one. That one is my new Sport Comp Amp gauge.
Below: Autometer used to make a couple of differnt types of bracket to hold the gauge into whatever panel you were using. They were not made to be used with the plastic instrument panel of our trucks. This is the new type bracket used today. It is a one piece plastic bracket to be used up against a flat sheet panel found in most race applications.
Below is one of the older type brackets that is a one piece metal form where the bracket fits the mounting screws on the back of the gauge with a leg on each side. It to is to be used up against a flat sheet panel.
Below is another type of older bracket but this type are individual brackets that fit onto one of the two mounting screws opn the back of the gauge and the leg goes up against either a flat sheet panel, or in my case I was able to either bend, twist, or grind shorter the end of the leg of the single bracket to fit up against the plastic instrument panel like are found in our trucks. All my old Autometer gauge mounting brackets are of this type. They were easier to fit around all the cast-in braces on the back of our instrument panels. If you go back to the first pic you'll see the older type single bracket used on my new Sport Comp Amp gauge.
