Rear shock mount problem
Snoots
Roger
Jimmy Sierra
Spooky! I had to run out in the rain with a flashlight and look at mine! Sigh of relief. At least until I remove the shocks and reveal something hidden. $hiite.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I’m not positive but I would imagine thats the way all suburbans are setup with the drivers side on a mount on top of the frame like that. Maybe not 3/4 burbs?
1/2 and 3/4 T are the same. Luckily, the failure prone bracket is only used on the driver's side while the passenger side mount goes through the frame. The difference is because the d/s shock leans towards the back and the p/s leans forward. The frame height at the two mounting locations is different (it drops down after the axle) so instead of having to use two different length shocks they just mounted the d/s shock on top of the frame to even them out.
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
****** update.
As honky said, was just going to plate it, drill a hole and mount the shock back, but when under there with the plate, nothing there is flat enough to weld the plate too.
Back to the drawing board. Gonna try to get by a local welding shop tomorrow or Wednesday.
Oh, thought about removing the bracket altogether and fabbing up a new or just having the extra room to fix this one... It's riveted on, no good way to get to all of the rivets.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I have more of the square washers I used if you want to go that route. If it's too ghetto of a fix for you I'm not offended. Just PM your addy if you want one and I'll send it out.
Dutch Rutter
Independence, Or
Joshua
Good luck with the local shop! hopefully they will be able to come up with a strong solution.
I had a thought about using a cutting torch, cutting a square chunk out of the center around the broken area then cutting a plate with a hole with the same dimension cut out and weld it into the bracket. But I don't think it would be strong enough to last a long while.
radio2000
South Carolina
83 and 88
*PM Sent*
I don't think it's ghetto. It's the only way I know to get it right short of doing the tank and drilling out the rivets to get the old bracket off and making a new one. What's the dimensions on those?
New shocks came in today, ready to get this big blue bitch back on the road.
Thanks everyone.
radio2000
South Carolina
83 and 88
The holiday delayed the delivery, but got it all buttoned up today at lunch. Thanks Skysurfer! Went with belltech shocks and now The big blue bitch rides so much better.
shmattly
kcmo
Steve
jimmy
These look nice, but this is below the original mounting point, right?
what brackets are they where can i buy
1lejohn
texas
john
k-1500, 2500 HD
Those are Unistrut washers. I'm guessing an electrical parts house , Grainger, McMaster Carr.
adhkjashda
