gmbellew
- May 27, 2018
- Kansas city
- glen
- suburban 1500
1990 V1500 Suburban. the driver door master power window switch stopped working for the rear passenger window. also, when i push the switch, it pegs the voltmeter down to the bottom of the gauge. the switch on that window still works. i am pretty sure the ground for all switches goes through the master switch, so i don't think it is a ground issue. i am guessing the switch is bad? does the switch just pop off the trim panel, or do i need to remove the trim panel? any other thoughts?
