- Feb 15, 2022
- North Central Washington
- Dave
- Scottsdale
Door panels came out really great. I would be happy with those on a work truck for sure.
Holy chit, Rob! Those look great now. I did see your update regarding clear coat and staining; that's good to know.while not perfect, it's a lot better.
Pix?I had a Datsun 208z a good 12 years ago
I still have that smashed POS parts car in my driveway, along with the clean-ish one (not crashed and rusted out, but newer and uglier bodywork I need to convert back to chrome bumpers from the ugly 80s plastic ones) I bought to toss the drivetrain onto. Yet another stalled project. I can take pictures if you really want, but nothing pretty at this point... The thing still fires up at the slightest bump of the key even with like 10 year old E10 gas in it. Idles rough after all this time, been sitting so long the clutch and brake masters have gone bad, but if you start it in gear and hold it to the floor it still does donuts lolPix?
Those panels will melt. Some years ago, I was using my backpack blower and for a moment I had to back up against my C-30 passenger side door (window was open) as I was blowing leaves. I quickly smelled plastic, turned around and saw a 2" diameter area on the top of the door panel that had begun to melt!Thanks, I think they turned out great too, and judging by your picture it looks like your probably looked great after the second pass, as the progress is obvious in the first.
Glad to know those methods work. I didn't elaborate in my post, but I read a how to somewhere and the guy basically recommended a torch if the panel was off the door, or a heat gun if it's on the door. I just didn't have balls. By the time I'd scraped and steel wooled them they were already looking so much better I was afraid of melting them or some nearby plastic. So I did a little more work with the steel wool, cleaned and put the treatment on them.
Thanks, 1 year later they are still holding up really well and no issues have popped up.Those panels will melt. Some years ago, I was using my backpack blower and for a moment I had to back up against my C-30 passenger side door (window was open) as I was blowing leaves. I quickly smelled plastic, turned around and saw a 2" diameter area on the top of the door panel that had begun to melt!
I finally did a refurb job on the panels and finished 2 days ago. They turned out nice. Yours did, too. I liked your well thought out and detailed, clear explanation of your process to prep and coat the top section of your panel. Mine had similar scratches but also included the unique "backpack artistry" to hide. Copying a process I saw someone else use for refurbing dashboards, I sprayed a few a few light coats of Rustoleum clear undercoater on the top section only and protected the rest of the panel by taping at the contours so any spray line could be blended and removed easily. The Rustoleum covered the damage and left a very light texture but with a slight sharpness I didn't want. That smoothed out nicely when I coated the panels, fortunately.
Here's a side note I'd like to mention for everybody about a great old product still available if you hunt for it. It's called a Preval sprayer.
I have no connection with the product or company but I recommend them because they work great. I found out about them and first used one around 35 years ago. Home Depot stocks them and they were fool proof for painting my door panels.Preval - Refillable spray system - Spray any paint!
Refillable DIY and Pro paint spray systems. Spray any liquid for professional results. Order Now or call to become a distributor 877-753-0021preval.com
