Pex door striker
Boltrunner
Odin mn
Shane
V20
I have a 87 r20 lwb 3speed with granny low. My wife has a 95 burban. Recently in her burban we have had trouble closing both front doors. Hinges arnt the best but everything still lines up and door sag is only about 1/4 in. Does the pex door striker mod work on a 95? I know they work on our older trucks but instead of joining another forum id rather just ask here. Hopefully someone knows and i can save some time. Thanks in advance for the help and information
yevgenievich
Viktor
sad
very sad
less sad
they have similar, but different dimensions. Parts store should have the correct part. 1/4" of sag indicates severely wore/damaged hinges. Hinge pins are easy to replace and should help some.
Yep, 95 body style is notorious for hinge pin wear. They sell the pins in the HELP section at most discount auto stores.
Boltrunner
Odin mn
Shane
V20
I guess i can replace her hinge pins. Though the money shod be going to my truck lol
Shilaeli hugger
Ohio
Burdaddy
V20
Ive done the hinge pins when i had a 99 'hoe. Didnt really care for it. My buddy fixed his daughters sonoma by weldin a lil to the hole for the pin and usin a long drill bit thru top hole and vice versa to fix it. No problems so far for her.
dixierj
