Performance 700r4 rebuild
Wumbo
Illinois
Rob
Basic OEM style sun shell. Gross, and disappointing really.
Wumbo
Illinois
Rob
Run of the mill 097 input drum
Wumbo
Illinois
Rob
The mighty Z pack
Has fallen
NickTransmissions
Las Vegas
Nick
R10
Does it say on the sticker on the case, when Hughes built that thing?
Using a round hole rev input drum when the third design square hole was available would have been odd.
I'm curious as to what valve body, accumulator mods were performed.
Is this an aux valve body trans (87-93)?
Were there two valve body check balls or just one?
How many .25" case check balls were installed?
Did the forward drum pass a pressure test?
Wumbo
Illinois
Rob
This post was beyond repair
Wumbo
Illinois
Rob
Does it say on the sticker on the case, when Hughes built that thing? Sticker is faded away
Using a round hole rev input drum when the third design square hole was available would have been odd. Cost saving, maybe?
I'm curious as to what valve body, accumulator mods were performed. Will be posting details soon
Is this an aux valve body trans (87-93)? Yes
Were there two valve body check balls or just one? One
How many .25" case check balls were installed? 3, and the captured check ball is removed
Did the forward drum pass a pressure test? Haven't tested yet
NickTransmissions
Las Vegas
Nick
R10
@Wumbo - For some reason this website isn't letting me quote but the round hole rev input drums are obsolete so yea, was def a cost cutting measure...Not the end of the world, just odd to see in one of their transmissions...Also odd to see Z-pack as it's the one Raybestos product that is complete garbage.
So far, from what I can make out on your parts table, your build is shaping up to be much more of a high performance build than what that unit received from Hughes...
Looking forward to more pics as you progress...let me know if you run into any issues along the way.
Wumbo
Illinois
Rob
Thanks Nick
I started assembly on the input drum last week, installed new bonded pistons and Transgo 7-CS return springs and orifice. Forward clutch clearance was only .005, so I had to order a thinner apply plate. It showed up today, so I had to install it. Forward clearance is .035 now.
Naturally, I installed the 3-4 clutch stack as well. Sonnax lists eight .067" frictions with seven .095" steels or nine .062" frictions with eight .077" steels as recommended clutch combinations.
I'm in the thicker is better camp, so I went with the first option.
Eight .067 frictions and seven .095 steels has me at .070 clearance. I think I want to be around .040, so I'm going to use some .080 frictions to get closer.
Wumbo
Illinois
Rob
Did some assembly
Sonnax reaction shaft, OEM 5 pinion planet from 4l65E. I initially planned to reuse the reaction shaft from the 65E, but it was too worn where it meshes with the ring gear.
New 29 element Borg Warner sprag, and Sonnax heavy duty overrun hub
Wumbo
Illinois
Rob
Big money
Sonnax input drum and input shaft. Borg Warner frictions, lindered 3/4 steels, plain steels in overrun and forward clutch packs.
I swapped out two .067 frictions with .080 frictions and the 3/4 clutch clearance came in at .045.
Leak tested good
The old drum also leak tested good, next thing I'm looking at is the third accumulator check ball capsule.
Wumbo
Illinois
Rob
New OEM reverse input drum, new frictions and steels.
New Borg Warner low roller clutch, and Sonnax smart shell race.
Sonnax wide sun gear bushing, and quick and dirty lube mod to sun gears. (I wanted to cut grooves on my Bridgeport, but didn't want to wake the neighbors, so used a grinder and cutoff wheel)
Nasty-LSX
TogetherforeverCovid19
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
BIG TIME MONEY!!!! At least you know its gonna hold. :happy160:
Wumbo
Illinois
Rob
Third accumulator check ball capsule leaks like it isnt even there.
Shot some brake fluid through it and that helped, but it's getting replaced.
NickTransmissions
Las Vegas
Nick
R10
Those rarely leak...try tapping it with a drift to reseat the check ball to see if it stops leaking...If not, replacement is easy as I'm sure you know.
michaelmarine53
