P/S pump pressure side fitting size on 97/07. Want to convert to AN fitting (pic's)
Nasty-LSX
TogetherforeverCovid19
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
I am updating the stepside LS FEAD. Removing the holley and putting a billet drive. I got a P/S cooler
for this setup and need a AN fitting for the pump. How do I find the size of the pressure fitting as I dont
have a old hose to go by.
Here is the new swap if you have not seen it yet.
This is where I am now. Video coming soon. Intake swap next
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
Im guessing this would be it!
If you are running AN line, you'll need the same fitting for the pressure port on the steering box. I believe the one you found is correct. Iirc, the return fitting on the steering box is a different size, so there are two different size adapter fittings on the market.
Also, if you want to get fancy, you can put a compression type AN adapter on the pump return outlet, and then run AN line on the return too.
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
got it all covered for the steering box. Just not sure on the P/S pump. :happy160:
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
Im going to run twist loc on the pressure side, and push loc on the return side with a large cooler. I know, its over kill. but it will also look good. :happy160:
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
Ok so I got the correct size. its not 18MMx1.5
the correct size is 16MM 1.5
are you using hydroboost? If not you would benefit from a type II (TC) pump, but that has a different fitting aswell.
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
No Hydra boost. The Holley mid mount was Type II.
rcguymike
