NV 4500 oil
1984dually
Malin OR
Danny
C30
8.1L
Swapping my Dually from a 4L80E to a NV4500 manual trans. Most use Redline MT-85 or 90 oil. Can't get it around where i live without ordering it. Any other GL-4 rated oil that can be used? Been looking at John Deere Hygard as it is GL-4 rated. Run it in all my race transmissions and it holds up very good and takes a lot of heat. Opinions??
bluex
Spartanburg SC
C15
I looked into this when I replaced mine. If the trans still has the carbon syncros you really need the MT85. It's the closest thing out to the factory oil specification wise. Other oils can cause issues in the long run, these trans are very picky about that from what I've seen
SquareRoot
The 4500 wil only live and be happy with a few specific oils. Don't know where your at but I have to order the fluids myself. On the plus side, you will pay less and can usually get it within 2-3 days. I wish I could still find the gm/Dodge stuff but I haven't been able to find it lately. I'm using the Redline in mine now and it works well. Not as well as the OEM stuff but that ship has sailed. My next oil will be amsoil. I've had great luck with their products. I would shy away from anything that doesn't specifically say for use in the 4500. It's not worth taking the chance of contaminating those carbon fiber synchros. Once that happens you'll be rebuilding the trans. I just built one, it's a lot of work, time and money. That's my $.02.
Linky: https://www.thebestoil.com/product/...ransmission-and-transaxle-gear-lube-gl-4-mtg/
3dbello
