Elliot W
- Apr 13, 2021
- CT
- Elliot
- C10
I went to move my truck in the driveway last week and it was acting like it was out of gas (I don’t have a working fuel gage). I didn’t need to move it anymore, but I put some gas in it and left it. This weekend I went to start it and no luck. No noise coming from the fuel tank led me to a no fuel pressure. Fuel fuse is good. Ground from sending unit is good. I have continuity from the relay to the sending unit, and the relay puts out 11.7v when I turn the key. But, it seems like the fuel relay isn’t clicking. I took out the relay next to it to make sure I could feel the click (or lack there of) so I was thinking maybe a bad relay, even though it sends 12v to the pump. I swapped the relays around and still no noise on the fuel relay but it puts out 12v as needed. I replaced the in tank pump with a walbro 255 thinking the old one was bad but it still isn’t coming on (I don’t think). Supply and return fuel lines to the pressure regulator are squishy where I don’t think it’s anywhere near 58psi, so even if the pump were quietly running I really don’t think it’s coming on. I’m not quite sure what to troubleshoot next. Here are the questions I have though:
1. Is the relay possibly causing this even though it’s sending the 12v but not clicking?
2. Can I bench test my old pump even though it might have residual fuel in it (is there risk of ignition)?
3. Should I test the fuel pump installed with direct wires to the battery to see if it comes on and is that safe?
4. What else should I troubleshoot?
This is a 5.3 LS with PSI Performance harness.
