No fuel in carb at start up
Eighty5ov
Canada
Ov
c15
Hey everyone,
I have a small issue. Recently I’ve been having to pour gas into the carb bowl for my 1985 to start. Even after a day or two of getting it going. Is this an oil pressure sending unit problem ? Any suggestions for what I should do first ? Thanks in advance
Hey everyone,
But it runs fine after it starts? What carb do you have?
Old Guy Bill
KY
Bill
Is it a Quadrajet carb? If so the well plugs need to be sealed.
I haven’t done it in many years but we used to epoxy them.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Floats stuck? Not allowing the gas in to fill bowls.
Eighty5ov
Canada
Ov
c15
It’s a quadrajet. It worked fine last year.
82sbshortbed
Fuckemall!!
SE Texas
Doug
How do I check that ?
I'd pull the fuel line to the carb and check the little filter in there to make sure it's not too dirty. Heck you can just put a new one in they're cheap. Then turn the engine over with the line in a bottle or something and see if the pump pumps gas to the carb.
If it is getting gas I'd tap the sides of the carb and see if you can unstick them. If not then you'll have to take the top of the carb off. I've never rebuilt one but I think you can get to the floats then and unstick if they're stuck.
Sometimes they stick after sitting for a while.
Are you pouring it in the bowl? Or down the throat. Leaky plug wells were a 1970 and prior deal,not saying it can't happen,but not probable. So back to what I asked are you filling the float bowl or dumping fuel down the carbureator primaries?
Old Guy Bill
KY
Bill
The epoxy would work, but it wasn’t a long term fix, eventually it would fail also.
There used to be replacement plug kits that had o-rings that replace the originals.
It’s been decades since I’ve worked on a Qjet though they may not be available any more.
Hey everyone,
No it's not related to oil pressure.
Eighty5ov
Canada
Ov
c15
I open primaries and fill where the jet of gas would have went.
Eighty5ov
Canada
Ov
c15
I will give this a try first.
Eighty5ov
Canada
Ov
c15
We have zero fuel coming into the fuel filter.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Fuel pump not check valving itself overnight?
Eighty5ov
Canada
Ov
c15
Where is the relay or fuse located for the fuel pump? Once I dump gas in carb it then fires up
JOD26
