Neutral Rub
Hound2022
Kibler, Arkansas
Richard
C10 Scottsdale
I have a 3 speed manual ( not the Muncy ) transmission in my truck. When I have it in neutral on idle you can here a slight rubbing noise.
Anyone know what this might be?
Hound2022
Kibler, Arkansas
Richard
C10 Scottsdale
Does the noise change if the clutch is pushed in vs left out, in neutral?
If so, I would suspect the throw out bearing and/or clutch cover is worn.
Yes, when you engage clutch it gets quiet. I believe you may be right.
Thanks!!
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
No worries, both my clutch rigs do exactly that.
3dbello
