OldBlueDually
- Jun 8, 2020
- Minnesota
- Justin
- 1976 GMC
- C30
- 455 Olds
Gent's, I need your advice on how to properly paint an aftermarket (not OEM) plastic bumper cover that came with black waterborne primer on it.
My wife smashed into a deer with her 2013 Chrysler Town & Country--took out the front end. I have the parts now (finally) and want to paint up the bumper cover and get this thing back on the road (she is driving our '01 2500HD Suburban and the gas is killing us!!).
I've called a few of the local paint shops and so far I have 3 different answers from *we've been told not to put solvent paints over waterborne primer by some people **sand it as instructed and paint it/clear it, you will be fine ***strip it down to bare plastic and start over with adhesion promoter/primer/sand it/paint/clear....
So, now I am quite confused on what actually should be done.
Are the instructions below really that simple, or am I "trying" to over-complicate this? What "I" would like to do (the simple way, of course) is use solvent based color, and clear over the existing black primer that is on the bumper cover by following the instructions. It states nothing about using regular automotive paints (solvent based).
Here is the EXACT wording on the label stuck to the back side of this bumper cover;
Water Borne primer painting instructions
1. Scuff or sand surface lightly with gray scuff pad or 1000-1200 grit sandpaper
2. Clean the surface with soap, water, lint-free cloth and air
3. Follow the painting instructions from paint companies for color and clear coats
Note: This part has been flame treated with an environmentally friendly water borne primer and is HPAs free.
What would you guys do? Or what have you guys done with these parts you've done yourselves?
Thank you!!
Thank you!!
