Mystery Bracket Under Dash
84 Silverado
Dallas
Tod
Silverado 1500
Team,
I can't remember what this bracket is for/what plugs into it??? I've circled the part that is in question.
Need15
Canada
Brad
I believe it is for the cruise control switch that holds the pedal in place once you set cruise
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Convenience center is in that vicinity I think.
Trucksareforwork
Spartanburg SC
Geoff
Pretty sure it's for the cruise control module. It doesn't actually physically hold the pedal in place but is the electronic module mounting spot IIRC. throttle on an '84 would be held by a vacuum servo on the firewall side of the carb next to the distributor.
nvrenuf
Mobile, Al.
Seems like the key buzzer and and a couple of other things were attached to that on my blazer but they're all gone now.
If equipped, a manual throttle controller also bolts to that bracket.
hip2bsquare
Jake
1986 chevy swb
1986 chevy swb
sbc-5.3 ls
on my '86 C10 that is the bracket that is related to the "convenience center". it may also have double duty as the bracket for the CC too.
good luck
lorisa2u
