My frankenstein
Ian Flynn
New York
ian
5L 305
Hello all,
I pulled a beautiful 1985 k10 305 5L out the field and am currently trying to get it started. I am out of ideas. I replaced the battery, plugs and wires. She turns over but wont start. The mechanical pump is pumping fuel. I am out of ideas. Does anyone have any ideas? Could a bad carburetor prevent the vehicle from starting? it seems link some sort of linkage is out on the driver side of the carb. Also there is a weird pump looking thing that seems to be rotted out. I would appreciate any help on this fellas
Ian Flynn
New York
ian
5L 305
When I spray starting fluid into the carb, it runs for a few seconds...so I know it wants live
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Obviously, the 3 basic things you need are air, spark, and fuel.
If you're getting fuel, can you verify its spraying in the barrels of the carb?
The linkage you're speaking of is vacuum modulator or whatever. I might be mistaken on that name. But it ties to the thing in front of your hand.
Since you're starting fluid is making it work, then you know you have spark to the engine.
The fact it runs on starting fluid suggests it's a fuel delivery issue.
Check the fuel filter, then if that passes, verify fuel is spraying out of the injectors in the carb.
The rusty thing you're holding in your hand looks like a choke. But I don't know.
Vbb199
Salisbury NC
Vince
Crummy floats in the carb can cause issues.
In general, gas that sits in a fuel system for decades does such terrible damage.
Even a period of 5 or less years. It just destroys everything and gunks it up.
Also.... WELCOME FROM NC! :D
Poppy 87
Bloomingdale GA
R10 Silverado
I believe the first picture is a linkage for cruise control, second picture I believe is an exhaust heat riser. Get fresh gas no matter what you do. Welcome from Georgia!!
animal
Lee
c10 silverado
350ish
:welcome:
Vbb199
Salisbury NC
Vince
There we go.
I never have understood what that diaphragm is,iI just know where it goes.
And the heat riser I would've never guessed.
Oaasport
Justin
Suburban V10
Being that it runs is a great thing. I would buy a $50 carb out of the junk yard. Drain the fuel tank, change fuel filter, run some air through the fuel lines and get her running!
RedGeneral
PA
R10 Custom Deluxe
Nice truck!!!!. Welcome, I agree get a cheap carb, Facebook, offerup anywhere you can, clean the lines get some fresh fuel.
to the land of busted knuckles and bank accounts.
Shorty81
Baby Boomer
North West ohio
Darren
Welcome from the Buckeye State. I have a Frankenstein truck myself.
Villano
