- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I'll wait till I get confirmation from CK on his make and model for sure, but I am beggining to think his TCC solonoid could be stuck in the on position. So if as soon as he hits 4th gear the TCC is locked, then I'd say that's it. The only reason why he is unlocking with throttle pressure and hitting the brake is because those override the TCC solenoid. Also just a guess and wonder if the governor may not be sticking, as when he slows down it should be downshifting. If it downshifts to 3rd on a slowdown, that should unlock the TCC also. Doesn't sound like its downshifting as needed either unless he floors it at which time the TV cable will take over and bypass the governor and cause a downshift.
