dkraven
- Nov 15, 2022
- Portland, OR
- David
- c25 Sierra Grande
The truck technically runs, I drove it around the block from the neighbor who gave it to me last fall, but it kept stalling due to a clogged fuel line. Aside from that issue it's generally been well maintained, though with long periods of sitting. I'm finally getting around to replacing one of the fuel tanks and its sending unit (saving the second tank for later) and when I go to fire it up I want to have the best chance at success. I'm handy and methodical and have done basic vehicle maintenance stuff, but this is a bigger project for me, so any advice from more experienced people would be appreciated.
Once I get the tank installed and fuel line and electrical hooked up to the sending unit, what do you all suggest to get the cleanest start? Obviously I need to put gas in it. I'm not sure if I should bother changing the oil before making sure it starts and runs, but I'm considering doing that. The guy who gave it to me sprayed starter gas of some kind in the carb when we started it, but not sure if I should bother doing that. Any other checks I should perform or tips you all have, I'm all ears.
It should say in my profile, but it's a 77 GMC Sierra Grande with a 350 engine, automatic transmission.
