Look at this deal.
Shaggy
Bryan
C30 Dually
Not bad at all for $800.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
What do you think those door panels are worth?!
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
That truck is a peach. If it wasnt so far away I would get it. How often do you see a truck like that, badged as a 400cid V-8, A/C, tilt wheel, cruise...and all on a '76 model! I think 76 had the Dana 44 front axle instead of the Corporate 10 bolt. Yep, if I lived within a couple hundred miles of that I would call him and tell him SOLD!
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
That is awesome
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I've finally convinced myself i cant get it. I hope he has not bent the hood yet, it looks like those hinges need lubricated.
85k10383
Glengary, WV
Ross
K10 Scottsdale
Wow, that is a hell of a deal! And its a desert truck also so you just know the cab is solid. Dammit, no money in my camp either....
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
If someone is serious about buying it and you live far away pm me, maybe i can help.
That is a sweet deal!
crazy4offroad
Curt
K-10
350/SM465/NP205
I could probably only muster the money for the truck. I have no idea how the hell I would get it home lol.
Must have been a good deal, its been deleted. And yep, a 76 has Dana 44 front axle if its OEM fo buh fo. If a manual trans, it also has NP205 trans case, but if auto its a NP203.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
It was auto, I have a 85 with a 305 and 4 speed manual, i have the crappy gm axles im sure, im not sure how to identify the font but i know the rear is the gm corporate 10 bolt. Should i have the 203 or 205?
crazy4offroad
Curt
K-10
350/SM465/NP205
The front, if it's a 10 bolt has a mostly oval cover/bolt pattern. The D44 has the typical offset cover shape found on other danas. You can google "axle identification" and then click "images" at the top and get a pic with all the different style covers to help easily ID what you have. I believe 77 and older trucks didnt use the double cardan front driveshaft and had u-joint yokes on the front of the t-case, instead of the flange for the DC joint. As for your t-case, it is more than likely a chain-drive NP208, not a gear driven 203 or 205.
Wrenchersllc
