Long Travel upgrade.....
8T6K5
AZ
L98 350 TPI
Been talking about it for ahwile: http://www.gmsquarebody.com/forum/showthread.php?t=4639&highlight=f250
But figured the install needed its own thread; so lets get this project started….
Before: Dual Rancho RS9000XL with 7” travel
The parts: ORD Zero-Rate Add a Leave, new U-bolts, Ford F-250 shock towers and Rancho RS9000XL 11.5” travel
F-250 shock towers…
ORD blocks – u bolts…
Old RS v. New RS…. Notice how fatter the body is too
Just over 11” of travel…
Midway point will need to be marked for later reference…
Old shocks removed….. sold on CL 
These rivets will need to be ground off and bracket removed…
Bracket off and holes hogged out to ½”
Notice fender well has been trimmed too…. (before here)…
Total amount of material removed…
Touched up with some rattle can…
On to the towers….. dry fitted – marked – masked and cut to size…
Remember marking the midway poin ton the shock? You want to install the new tower at that point.
Crappy pic, but remember the two rivet holes drilled out? Use the top one for the tower top bolt. Mount in place and tap 2 additional holes (1/2”)
Remember the fat shock bodies? I had to notch the lower mounts to fit that sumbeech in there…
Mocked up, awaiting grade 8 hardware…
Great write up man.
8T6K5
AZ
L98 350 TPI
Driver4r
Nebraska
Trevor
k10,c20
What are you going to do with the old brackets?
8T6K5
AZ
L98 350 TPI
Old OE brackets I threw in my neighbors garbage disposal.
Brackets and shocks for dual kit was sold on CL.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Nice, I want to see it going to work now. And I don't mean some roadside berm!
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
What king of brake calipers are you running?
Is that a Y-pipe behind the headers?
8T6K5
AZ
L98 350 TPI
Day Two:
Installing ORD Zero Rate Add a Leave’s and new U-bolts:
Install is pretty straight forward. Lift truck, I used a floor jack under the diff then put a bottle jack under the leaf-springs, as close as you can to the perches. Slowly drop the floor jack until you have room to install the blocks.
I had shims in my front end…
Final product:
On to the top:
Started getting dark, Ill get more up later:
8T6K5
AZ
L98 350 TPI
You running a catalytic converter? You got one pipe the rest of the way out? You running a O2 sensor?
8T6K5
AZ
L98 350 TPI
One pipe out with cat and 40 series.
What cat you running? Factory or high flow? You got emissions testing?
8T6K5
AZ
L98 350 TPI
Dunno what cat, due for emissions in one month......will let you know how that goes.
sszcam
