Lokar throttle/ kickdown cables
86suburbanNJ609
South Jersey
Aaron
Suburban
Hey what's up guys I have a question to ask. I have a edlebrock 1406 carb with the 700R4 trans. The current throttle setup on my truck is a cheap POS so I got the lokar corrector bracket throttle cable and kickdown cable. Has anyone used this setup? And if so how should I go about hooking everything up? Just need some pointers I just want this thing to be on point and don't have much to work with as for as instructions.
Thank you in advance or at least a thread play by play for the complete instal
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Is this the stainless steel kickdown kit? If not, do you have a PN? Haven’t used it, but I’ll see what I can figure out, if anything, on my end. At least until someone who has replies.
86suburbanNJ609
South Jersey
Aaron
Suburban
Yes the stainless one.
4WDKC
Southern Florida
Kacy
that is not a kick down cable to the trans, having it adjusted incorrectly will burn up your trans.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Throttle valve cable. What part are you trying to replace mainly? The throttle linkage setup I’m guessing?
86suburbanNJ609
South Jersey
Aaron
Suburban
Yes the linkage at the carb with the bracket and cables. I just wanted to know where to start. I never have done it before just wanted some info before I go tearing more **** up.
4WDKC
Southern Florida
Kacy
Whats wrong with the stock cable for the trans and can you use a stock one for the carb?
86suburbanNJ609
South Jersey
Aaron
Suburban
No it's not stock it looks like the cheap setup from advanced Auto
starlinstephens
