Lets see your lifted trucks
77 K10 SWB 350 SBC, SM465, NP205.
6" front springs off K20 (may be a little more lift than a 1/2 ton 6" kit).
56" K20 rear springs w/ ORD 4" shackle flip + AALs & ZRs.
15x8 wagon wheels with 38x12.5-15 TSL Bias.
Running 10 bolt front/12 bolt rear w/ 3.73 gears.
Soon to have 14-bolt full floater rear/Dana 60 front/5.13 gears, 38x12.5-16.5 E-range TSL Bias.
Also located a set of 16.5 H1s for $200.
This one is my favorite.:High 5:
Swims350
Logan WV
none
ok let me throw up some of the old 86 dad had...
Other than the stick on hood scoops I love the one that Swims posted :drool:
Here is mine..
^^This one here is pretty sweet too but needs just a little bit bigger tire. Love the paint scheme and lift on it, though.
Swims350
Logan WV
none
our black one needed new tires, it had 33's on it when it was stock and those pics are with 4 inch lift, needed 35's or bigger. it also needed alot of body work. Door skins, rocker, fenders and inners, and then the bedsides sanded down to bare metal and rust stripped then repainted. We ground it all down(except for the bed) and fiberglassed and bondo'd it all. it held up good for over 4 years I think, as you can see in the pics. The doors had fist sized holes in th elower back corners, rocker the bottom pinch weld was coming off the main rocker all the way back to the step, floors and inners were perfect, bedsides were new before we got it. We put the cab corners on but never finished behind the bed/cab area. The front fender lips were bad, and lower corners in back and then the inners had huge holes that we tinned over. Had a brand new rebuilt 350 that we built, new carb, fuel pump, everything inside the motor new, radiator, water pump and hoses all new, including the heater core, a/c we took out, trans was on it's way out but we had a th350 built to replace the 700r4 perfectly(bolt up no mods) it never made it in the truck, it's now in my 88 k1500. Tires, brakes, shocks all new, and lift was only a couple months old same as the exhaust, and it had long tubes on it.
CknightK10
California
Thanks, I havnt had the funds for tires yet. Its got the ORD shackle flip and zero rates and im working on a crossover steering setup.:pedobear:
All these trucks are bad ass. Get that Ford the F outta here!!!:Jedi:
I'd love to lift the Burban.
Ditto !!! WTF do we wanna see a Ford in comparison for??? I'd tolerate it is was on a truck forum, BUT, we are a specific breed here, and specific year modesl too, so we have the right to bash other brands on this forum.
It woulda been cool of some of those people woulda hung out and stayed around.
Here is mine..
NIce Rig Night. Welcome to the SB Forum. Hang out awhile and learn some ****, :poop: and share some ****. :dancingpoop:
I hear ya man! :) very nice rig
nvrenuf
Mobile, Al.
Here's mine...
91 K5, 8" lift w/ 43's
For perspective, I'm 6' tall
:popcorn:
You need some bigger tires on that I think.....:hidesbehindsofa:
zch5575
