Larger than "normal" bellhousing inspection plate?
clintC
Louisville, Ky
Clint
C3500
the inspection plate I ordered is not wide enough & starter hole too small...can't find part # / info on a larger....will look for bellhousing part# this evening...81 c3500 350
nvrenuf
Mobile, Al.
If it’s not wide enough then you don’t need a “wider than normal” part, you need the correct part.
clintC
Louisville, Ky
Clint
C3500
4 speed conversions has the inspection plate for the truck/12" bellhousing
3dbello
