- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
so for mine to get on the opposite side of dipstick which was still sealed with the o ring and clipped down, and the vent half way down the side of trans, do you guys think maybe the modulator bewing ruptured means the pressure changing and expansion pushed it up the vacuum tube which either had a drip loop to that spot or made its way out of a spongy part of the hose im sure was spongy befroe it was put on teh modulator let alone atf contact. it doesnt appear in the openings of the carb or the body. so im not sure it was pushing into the qjet.. which is why i am gonna ask if maybe it could find a way to the top of the kickdown bracket and then make a downhill drip onto that cavity on intake? The line looks not ATF but if its had time to evaporate any small clinging and otherwise travel downhill till the end then maybe?I had a similar issue with atf on the top of my engine and exhaust manifold. It turned out to be a clogged vent tube. A TH350 with the vent on the left side like the pic. When the trans was warm atf would come out of the fill tube since that was the path of least resistance. I used a pick to loosen the dirt and compressed air. I refilled as needed and never had the issue again.
well im not an expert but that kickdown line looks a its a little bent considering its a high tension plastic sheath around a coated metal strand wire cable and that woud impede its smooth movements and the clip from the adjuster is also missing.... and the adjust is pulled all the way back because of im sure the first moment the throttle was snapped and that cable tried to do anything... infact it looks like it shot back, hit the harness conduit and bound up at an extreme turn for the thing or just happened in relation to the slight sauna it was experiencing one day. I dont know how interchangeable or universal they are but i have one thats from a square in good shape chilling on a bracket for i presume sbc but it might have a different adjuster body
the bracket also looks like it got bent upward and to the left where the kickdown goes..
Hmm.. im getting a bigger light and seeing what is all visible on this back of engine and trans because a couple vacuum lines are visible sneaking behind the engine and I really hope they are ones that show up in front and not going to the vent lol. Looks like the top down one is for the modulator.. i think?the drip on that vacuum diaphram thingy bobber is from me pulling the dipstick and it being all the way to top so it dripped a bit while i was swinging it out
That sounds bad
