How to turn throttle cable 90 degrees?
Bitterguy
San Antonio, TX
Jason
So the integrated head on my '79 250 went kaput and I decided to switch over to a non-integrated one. The intake that came with the head is fitted for a 1bbl carb but the way the carb sits on the intake the throttle lever runs east-west where the old one ran north-south. I can't for the life of me figure out how i can route a throttle cable to pull east-west and google is failing me. Has anyone else had this problem? If so how did you rig up a solution?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Park sideways in the spot? Then even if it's a north facing parking spot, you'd be facing east...
Keith Seymore
Motor City
Keith Seymore
4.3L
A bell crank, or a cam.
Bitterguy
San Antonio, TX
Jason
Thanks! that seems like it will work now I just have to find a way to actually attach one to the intake.
Pics. I can't se how it could be hard to reroute a cable. It's a cable,it's flexible move the bracket/ make a bracket to hold the cable so it lines up with your new carb. I'll find some pics or take some pics brb.Pic 1 north south pull 75 k I could move the cable mounting bracket to the left valve cover turn it 90 degrees now it would pull east west. Pic 2 VW Rabbit I could move that bracket to the valve cover point it forward and it would be north south. Pic 3 84 C10 I could move the cable bracket to the left valve cover point the cable towards the right valve cover and now east west. Pic 4 Ford festiva, east west,turn the bracket 90 degrees move it back it now pulls north south.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
On one of mine I turned a quadrajet 180°, I just got a longer cable from an 88 lumina or something
Better examples. Last one is sideways
sparky77
