help with c20 drop..
ozc20
australia
sean
hey guys sean from australia here..
i have an 86 long bed c20 8 stud and want to get her low to the ground..i can’t buy much here for it so most i get is from the US.
the rear seems straight forward is the front am struggling with..i seem to be able to get spindles for clip on calipers but not bolt on.can i change my set up to clip on calipers?? is that possible/easy to do?? the truck runs dropped springs and dropped controls arms but just want that extra 3 inch drop so i can tuck some wheel. any help will be appreciated
cheers sean
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Don't know if this will help you mate, or if you will even see it, but I ran across a link in another thread that addresses the issue. It gives you the choice between bolt on or clip on in the fine tuning part of ordering. Hope it helps Sean.
JOD26
