Kheughens
- Jul 14, 2023
- Los Angeles, CA
- kirk
- c20
My experience with the HEI distributor (ACCEL 59130 with coil) is you must use the vacuum advance stop plate. Initially, I did not install the stop plate and the first time I hit the throttle, the results were not good. Vacuum advanced with no limit and did not come back down. I ended up trying a few settings but found for my vehicle, the “c” option 8-11 degrees worked best (1973 350 stock Chevy). Your configuration may be different. BTW, best decision to move away from the original points based distributor!
