Gauge ground location
80c10305
Sabin,Mn
305 v8
Hey all. Working on my 1980 c10 and I have intermittent not working issue with the volts/water temp/oil pressure gauges. Fuel gauge does work. I’d like to check the ground but not sure where the darn thing is. I’ve already replaced the ground strap from cab to engine block, battery to block, block to frame.
Now thinking bout it, I’m thinking it’s a bad connection on back of gauge cluster. Is my brain going on the right direction?
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
You are on the right track for sure. think it should be same as ours but under dash and connects to the emergency brake housing frame.
80c10305
Sabin,Mn
305 v8
10-4. Thank you!! I’ve been chasing gremlins for a yr and I’m slowly getting them squared away.
75gmck25
Northern Virginia
Bruce
Missing cluster ground will cause a variety of dash problems with lights and gauges. but for some reason the fuel gauge might not be affected. As mentioned, there is a ground post on the emergency brake pedal mechanism, and a black cluster ground is connected to it.
On newer trucks they added a ground bus bar on the firewall up under the dash, but I don’t know the year that started.
80c10305
Sabin,Mn
305 v8
Score!!!! Thanks for the info.
  • Like
Reactions: WFO
3dbello
