- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I normally just look for a capacior that is swollen or leaking, or any other little component like a diode that looks like it got hot, or a spot around the board where a component got hot, and start from there. Capacitors you can usually read the casing on what it is, a diode you can identify by it's stripes, then look up the values for those parts and with a DVOM (Digital Volt Ohms Meter) test the part by putting the leads on both sides of it compare the values. When you find that one or 2 that are not within the correct value, that's likely the culprit. Many times, you'll find the diode you need and go to Radio Shack and buy a 5 pack even though you only need 1 for $1.99 or $2.99.
This is also why I kinda hoard ****. Computer motherboards, power supplies, circuit boards from TV's and such, then at those times I don't feel like going to Radio Shack, I'll look on other boards for little parts that have the same value and sometimes can get by robbing them off of a salvage board.
I once fixed an electronic circuit board for my rent house's Central Heat and Air unit with a used part. The board was going to have to be special ordered, take 7-10 days to get leaving my tenants without heat and cost $220+. Saved with a FREE used part from a computer motherboard IIRC. I wish I could get good at soldering. If the parts are to close together, I don't do a neat enough job to make all repairs, although I'll at least try until it's beyond repair.
