- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
The other two are visible checks for functionality and are supposed to be observed while cranking the engine (no one ever does).
While the key is twisted to the start position, the coolant temp gauge (and the brake warning light) are shorted to ground through the ignition switch. The temp should peg out high, the brake light should illuminate.
If everything is wired right, they do actually peg high and light up respectively. Watch sometime.
I checked this test function yesterday. My temp gauge does not pin or attempt to do so while in crank position. I believe my oil light is combined with the brake light. That comes on with key on, no parking brake, then stays on at crank until pressure builds on the oil gauge then the light goes out.
