Fuel injection conversion
martingmc86
california
martin
gmc sierra 1500
v8 5.0
Carb'ed Vortec 350
I was looking into this one since you mention in it it’s interesting since it can connect to the tps the mixture control solenoid but what about the esc
I don't know anything about swapping to efi, my old vehicles are still carbureted. What I found interesting is that the throttle body kit on JEGS shows the E.O number and is compliant in CA. But the same throttle body kit that includes the fuel pump kit is not compliant. Hence, LAME!
But, the same kits on the Holley website are both 50 state legal and say they are CARB compliant.
Hopefully the other members with knowledge of these systems can answer your questions.
If you don't have the FITECH unit yet, your options are more open and you can also ask the tech services, as they will know what works and what does not work with their respective kits.
I don’t need it to be smog complaint I want to know if the TPS needs to be spliced in to the fintech and the ESC still need to be connected thank you guys for your help
The 305 is notorious for being super sensitive to detonation when the ESC is not functioning properly and also being a total dog if you retard the timing enough to not detonate without it. You need to see if the FiTech documentation actually tells you what the spec is on the TPS. If it doesn't you can call their tech support and ask. Stock GM TPS will read 0.5v at idle and ~4.5v at full throttle. You can always just measure the signal on the FiTech and see if it matches the stock output. If it does, then splice it in so the ESC continues to function like it should. If not, then you are SOL.
86Blueberry454
Kevin
I just swapped a Holley Sniper system on my 86 C10 with a 454 last year, this was formerly a carbed 305 truck. I don't believe the FiTech is much different in the aspect it will control all the same things as the Holley depending on how you decide to wire it and the parameters you chose in their handheld. These Throttle bodies have built in TPS so you wont use any of the electronics from the carb. The FiTech should have instructions available to read before purchase (summit racing) to give you an idea how to adjust the TPS as well, which is probably as simple as turning a screw and turning the ignition off and back on to reset it to 0. I found it easiest to eliminate all the factory sensors and majority of the engine wiring harness. You could also swap distributors to a FiTech one and make it more plug and play if FiTech cant direct you what to do with that connection on the oem distrubutor.
mattyb
